so as you can see, the area near the latch is blocked off by a sheet of metal. I tried to see if I could unscrew it but its all welded together. so then I tried to stick my head in the little spot to see if I could see anything from inside the door and this is what I saw
so this black bar that goes up to the top of the window is in front of what I need to try and fix.
so my question is, has anyone else had this problem before? and if so, how did you fix it? I'd appreciate a response ASAP... my father in-law wants to take a saw to the door tomorrow and cut part of it off to try make room to work on it.
