breadbox wrote:Open the hood check trans fluid level and look at your passenger side fuse box and make sure all three plugs on the left side parallel to the firewall are plugged in. Make sure the shifter is connected to the trans. Then I guess the box that controls the trans might be F'd or your trans is.
So it starts but doesn't drive?
Yeah the car turns on fine and everything. they said it ran before and they his friends started messing with it and then it wont drive any more.. like its go in and like nothing dont move at all. i starts everything sounds find. no wierd sounds from the transmission or motor
