Need HELP with ATF!!
jimufine
Car: 2002 Infiniti QX4
I tried a search. I just did a trans fluid flush. How many quarts do I fill back? I did 2 1/2 quarts of ATF. I own a 2002 Infiniti QX4. I did a search and saw some things like 10 quarts!!?? Please help me quick!!
FarFetched
Car: Suzuki SV1000S.
read the manual on how to check the transmission fluid, follow the directions and everything will be clear as "mudd"
jimufine
I did, but you know how you fill the ATF in through the dip stick, I guess there is still some ATF in the tube, so it kinda gets all over the dip stick while I am putting it back in, thus giving me an inaccurate reading. Should I just wait a while before checking again to let all the ATF thats on the side of the tube settle into the transmission? On a normal drain a refill, how much do you guys put back in?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Did you do a mechanical fluid exchange. or just a drain and fill?
If you didn't do the exchange with a filter, gasket replacement and pan clean, you didn't accomplish much.
jimufine
I understand that it may not have accomplished much, but all that aside, I just want to make sure there is adequate fluid as to not burn up the trans. Any input on how much to put back in a standard drain and refill?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Yes, you replace the exact amount you drained, then measure per FSM or OM.
