Need help with Apexi SAFC install
s13drft89
Car: 1991 Twin Turbo 300zx & 1968 Mercury Cougar
Hello,i had posted up for help on putting in my apexi safc, well some people had given me the diagram on how to hook it up, and well it does not match up to my ecu harness, it matches up to the sr20det harness. On the ignition wire(red) it shows it to hook up on the right second to first wire, well that one is a ground, and the third one is the ignition wire, on my ecu. Iam not sure about the other wire such as throttle air flow etc.. is there anyway someone can post a picture of the wires they hooked it up as,meaning taking a picture of the ecu with the wires hooked up, please anyone help I have a 1993 240sx dohc and the apexi safc is the version 1 AND YES I HAVE TRIED APEXI's WEBSITE AND I CAN FIND NOTHING
Modified by s13drft89 at 4:08 AM 8/6/2005
Florida240sx
I'll save you. give me one sec to get you the link.
Florida240sx
I used this exact model but used a different ecu ground. Think it is top left or right above the power which would be top right. hope it helps. http://web.ics.purdue.edu/~tme...c.htm
dj_hype
Car: A Nissan
will that model work for a SAFC II and an s14 ecu?
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
If you go to http://www.zeroyon.com you can upload the entire PDF for the s13/s14 Factory Service Manuals, and they have the complete wiring harness diagrams. I used the diagrams for my s13 ecu, when I wired my SAFC....
Tj@TomsAutoPref
i have a 89 s13 with a sr20det, is this the same proceadure for my car as well?
