onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Tue May 20, 2008 10:39 am
If your battery is not charging, and your alternator & battery are tested good, there's only 1 thing left -> the wiring from the alt->battery.
You can do a simple trace w/ a multimeter to find out where the charge is being lost (i.e. w/ car on, battery level is probably hovering @ 12v instead of 13.5-14v like it's suppose to be).
You may have just popped the alternator fuse.
If you still can't find it (or can't figure out how to trace wires correctly), I'd suggest asking someone local who knows how to work on cars to show you or just taking it to a mechanic, otherwise, keep on truckin'.
It's difficult giving directions over the internet w/o the actual problem car in view... much less they way you describe your problems.
