need help with an alarm . compustar 2wss-as for my 95 240
etmoron
so i attempted to install the alarm on my car . first alarm on any car acually .
now the car arms and disarms fine and remote start is ok .
but i cannot get it into turbo mode . i think i did it right , there was only 1 wire coming out from the ebrake so i just spliced the ebrake wire from the alarm to that wire . everytime i try to set it too turbo mode the 2 way pager just chirps and the lock and parking lights blink . did i install something wrong here ?
also when i press the remote start , it seems the the car cranks are very short and it usually takes the car a second time to crank and then fully start . is there i way i can make it crank for a little bit longer ?
thank you
double_jd13
Car: 96 240 w/s13redtop
did you hook up the clutch wire also? i couldnt tell for sure but does it go through the process were it doesnt shut the car off till after the door shuts? you can also turn on the turbo timer also i believe from the remote. unless you have the new one and they stop putting on instructions on the back of the two way remote.
email me and let me know i have an old one i had on my last car and are about to re install on my 240..
and you did not cut the jumper wire in the brain correct?
jason
