VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Sun Jan 08, 2023 11:04 am
That I can't tell you, it depends on your stereo. The '15 Rogue has a split CANbus where the BCM acts as a gateway, MCAN2 has the AV Unit, HVAC control, AVM, and Radar, with double terminators at the BCM. The cluster and everything else on the car talks to MCAN1, so you probably have some sort of format issue with addressing or identifying messages passing through the BCM from MCAN1 to MCAN2.
