Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Fri Nov 07, 2008 12:18 pm
AS SHOWN ON PAGE AT45................in FSM!
Code 2 is something involving speed sensor, the frequency to voltage convertor on rear of speedometer, the voltage distribution circuit that isolates the 0>5 volt signal to the speedometer, PS, CC,ECU, and TCU.
Trace the 0>5.00 volt to TCU.
Any problems with PS stiffness, speedo, what about ECU codes.
Easy to trouble shoot with Consult as you can view 0>5 as it occurs in TCU.
All in all it takes about 5 minutes to TS with Consult to decide whether to swap TCU or some other components.
