need help with a problem...
tony/ka24de
my 1992 240sx bogs and stalls when the car is hot after turning off the car for 10 min or longer. this doesn't occur when the car is running from a cold start. (eg. start car,go to the store, come out of store, car won't start.)(only happens when engine has been turned off when hot.) Does anyone know what this might be.
24_4life
Will the car sputter at all after warmed up. If it misses you might want to check your ignition coil. I have heard that when they start going out they will quit working after heating up, but then when they cool down they work perfectly fine again.
I'm not sure but its an idea I guess.
