3rd Q »
https://forums.nicoclub.com/3rd-q-u15667.html
Fri May 05, 2006 6:17 pm
Wes,No, I don't feel it or hear it at any speed once underway, only at a stop when there is a load on the drivetrain as it is in gear. My original exhaust had lost that heavy rubber vibe isolator on the rear of the exhaust and even then did not have this vibration. That exhaust system was replaced since it was leaking under a heat shield up front- put the exhaust from my parts car on and guess what- leaks in the same place. I'll weld in a section as a temp fix, maybe I'll be in on Jeff's group buy for exhausts .
Drew,Well, I was thinking of replacing the trans mount, so I think I will just in case.
Weird that it started all of a sudden, and does it pretty consistently now but with varying degrees of vibration. Starts about 10 seconds after I come to a stop with it in gear. Haven't had this on either of the other 2 Qs even though they had 30-70k more miles. Perhaps as Q45tech has said rubber has a life expectancy- may have exceeded its shelf life.
Thanks, guys!Any other ideas welcome, also.
Paul
