need help with a camshaft question...
naha_music
Car: '14 Ford Flex Limited
'05 Audi A4 Quattro
'02 Chevy Blazer 4x4
'99 Nissan Silvia Spec R
'86 Pontiac Fiero GT
'49 Ford F1 w/ Flathead V8
i got a quick question, can someone please explain what the difference in the degrees & steps for the intake/exhaust camshafts? for example, HKS makes some camshafts that are step 1 256, step 1 264, step 2 256, etc.
link below for example:http://www.optionimports.com/engineparts.html
thanks for any help...
need2drift
Car: 89 s13 sr20det powered coupe
not tryin to be rude but just do a search for"cams" this topic has been covered alot.....
spider_slayer
Car: S14 240SX
S13 240SX
Nismo_Freak
Car: 89 Nissan 240SX
naha_music wrote:i got a quick question, can someone please explain what the difference in the degrees & steps for the intake/exhaust camshafts? for example, HKS makes some camshafts that are step 1 256, step 1 264, step 2 256, etc.
Degrees are a duration marker. Greater the duration the higher the cam's efficiency takes place in the power band.
The different steps are for different valvetrain mods (ie. some are for aftermarket springs, etc.) and involve different amounts of lift.
If you are making sub 350whp I'd suggest Tomei 256's, if you are wanting more than that then I'd suggest no more than the HKS Step 2 264's for a street car.
