rickittoutkast »
https://forums.nicoclub.com/rickittoutkast-u123902.html
Fri Jan 09, 2009 8:20 am
ok cool thanks for the help/ reply..anyways the transmission fluid looks relatively clean, and smells very very slightly burnt, i am gonna change it when i get paid at months end, the plugs might also need changing, planning on putting in a set of NGK Iridiums. i have not the time to check it out as yet... i jus wanted to know how serious the jerking problem was and the cold starting. when the car is warmed up there is no problem with the car engine.. it works and sounds beautifully....:-), i will also check the mounts, thanks alot for the suggestions, laters....
