Need help with A/C...
Drk_Drftr
I just swapped my Red top SR in to my 92 S13 Vert and it is the first time that I am running A/C and I dont't know how to mount it. I have the original SR a/c bracket and the ka pump attached to it using the 2 top bolts for mounting but, is that right? When I look at the a/c pulley, it looks kind of off center, almost like it is leaning backwards. When I test started the car the belt slipped out of the crank pulley grooves and jumped to the P/S
So is there another combination of bolts that will make this thing sit correctly?
O yeah and not only that, my intake pipe hits a part of the a/c aluminum lines, so also wtf?
I'm retarded at searching btw......
Kalypso
get more reference pics from around the forum.and take a look at how it should sit.
then get back down there, and study you're install patiently. thats more effective then the "interweb"
when searching, put in one term like A/C or AC and then sift through the topics to find something pertinent. start with short terms then build up. and also look in certain sections vs the whole site.
the Search will become you're friend there are NO new topics.
