Need help with a brakes problem
kainvamp
Car: '91 Sil80 w/ SR
Well i was getting ready to roll out the driveway to work thismorning when i suddenly had no brakes. I figure it is the master cylinder, since the pedal goes straight to the floor with no pressure. My question is how would I know if it is the master cylinder or the brake booster that f'd up. The resevoir was still full so its not a leak or anything. A quick response would be greatly appreciated.
kainvamp
well i didnt really understand how the brake booster worked until i just read up on it, so im assuming its just the brake master cylinder now
Hijacker
Car: '92 240sx Convertible
'94 F-150
the internal seals on the MC probably went bad so instead of the fluid staying in the line or even leaking anywhere, it just goes back into the resevoir. Master Cylinders aren't too terribly expensive.
blackmagic
Car: 1995 nissan 240sx se w/ rb26dett
Im with him^
Vegascorbin
Car: 1990 240sx dirt track race car
When the brake booster goes bad it will be hard to press on the pedal. Teh same as if the engien is off. usualy when they go bad sudenly you hear it. It will "POP" just like a balloon. And your pedal will get very hard to push all of a sudden. (ask me how I know this )
nismoracingsx
Car: 1993 White 240sx Coupe
before you throw a new master cylinder in, check for any external leaks throughout your system. Also, you can pump your brake pedal and have someone watch for bubbling in the resavoir (alot of bubbles normally means bad seals).
GL
