need help with a 90 pathfinder/trans. or transfer case
TnT=rgis
Car: 93 vert
i have a 90 pathfinder xe v6 auto 4x4. it started making a noise that sounds like it is coming from the transfer case or transmision. i was on the highway and let of the gas to exit. when i did it started to whine like worn or dry gears or bearings. it continued to do that for a few days then it suddenly change to a cluncking sound. it clearly sounds like metal to metal now,like a bad universial but they are good. so i assume it is the bearings in the case or tail of the trans. dose anyone know what items are the first to fail/what to look for? and will a 4cyl 5spd picup trans mission and or transfer case swap in??? i have access to these parts cheap. just wanted to know if they will work with the addition of a v6 bellhousing or not???
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
I think you can tear down both cases and replace the 4 banger input with the V6 one. The difference is 24 vs 30 splines, but everything else in the Tcases is the same.
