Need help with a 1977 280Z
77zcar
Car: 1977 Datsun 280Z.
I am new to the forum but not new to Nissan. I have just aquired a 1977 280z and I am having a hard time getting it running. It’s been sitting for 8 years and they said it was running when they shut it down due to a reverse issue. I would like to take it to some one, does anyone have any suggestion for the Central Florida area?
nissangirl74
what have you tried so far to get it running?
lne937s
Car: 2012 Nissan Juke SL AWD
A few things to check:
-Does it turn over?
-Is it getting spark? Pull the plugs and check.
-Is it getting clean fuel? Fuel that has been sitting a while can thicken and clog everything up. I am not sure if Florida had the ethanol mandates 8 years ago, but that can cause further corrosion, break down old fuel lines, attract water, etc. This is what I would assume the issue is.
If the car checks out on those three things, it should start. Getting it running right is another matter.
77zcar
I have dropped the tank, cleaned and treated it. Replaced the fuel pump, fuel filter, all six injectors, fuel pressure regulator. Replaced six plugs and we are getting spark. The cold start valve is working. Cleaned the distributor button. I'm stuck.
77zcar
Also, it does turn over. I have gotten it to idle and it has seemed to have blown out some of the carbon but now it's being stubborn.
SHIFT_Z
Car: On 4's
2019 Subaru WRX 6MT
Former:
2014 Chevrolet Cruze 1LT
2006 Nissan Altima SE-R 6MT
1988 Nissan 300ZX 2+2
1985 Nissan 300ZX Turbo
1986 Nissan 300ZX Slicktop
On 2's
2018 Kawasaki Ninja 400 ABS
Possibly one of your temperature sensors? (Cylinder Head Temp. Sensor?) I'm pretty sure when those start to go bad, the idle / running abilities of the car start to get punished.
77zcar
Okay, I'll try that. Thanks,
