need help with 5 lug conversion on s13
blake89240sx
Car: '89 240sx
okay, ive searched and i see that you can use the NA z32 rear hubs for the swap but not the front. i have access to a z32 and the parts are free. so is there any way to make the front hubs work on an s13? thanks
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
No there are very very different, but take the rear uprights and all of the brakes.
blake89240sx
Car: '89 240sx
well then what is the best and cheapest option for the front? i dont have access to any s14s but pullapart in montgomery has plenty of j30s
bersh240
j30 works...after some work.you have to cut a new retainer clip groove and then press in s13 bearings.if you have acces to a lathe and press. do it. im probably gona end up doing it that way.
blake89240sx
Car: '89 240sx
are there any options that would be a direct bolt on like the rear is?
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
The only bolt on options for S13s are Attain/GTO (not the s***ty GM car, but the Japanese brand) front hubs, Ichiba or S14 (only if you use the S14 knuckle, lower control arm and S14 tension rods)
Dazzla
I used z32 NA rears, and bought new OEMs for the front. That's the best way to go 5-lug imho
blake89240sx
Car: '89 240sx
ive got another question. me and my friend are taking the brakes off now, and i was thinking.. im gonna use his lsd on my 240 but his output shafts are too long. but since im doing the 5 lug conversion too, couldnt i just use his entire rear end?? the lsd, output shafts and wheel assembly
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
not the axles, they are too long
blake89240sx
Car: '89 240sx
how much is too long?
ILoveMyRHS13
Too long to where as it won't work.
blake89240sx
Car: '89 240sx
well then i guess ill be getting the j30s then. the z32 parts are free so i was hoping they might work
ZakinaS13
Car: 90 S13 w/ 98KADE
Put your S13 output shafts in the Z's lsd. Presto!
Jagstang
Car: 1995 S14 w/ Kouki S14 SR20DET
Dazzla wrote:I used z32 NA rears, and bought new OEMs for the front. That's the best way to go 5-lug imho
Hey Dazzla, my BC bud, where did you get your z32 NA hubs from? And what about the new S14 front hubs? Let me know, thanks.
slow40
Car: S13
ILoveMyRHS13 wrote:The only bolt on options for S13s are Attain/GTO (not the s***ty GM car, but the Japanese brand) front hubs, Ichiba or S14 (only if you use the S14 knuckle, lower control arm and S14 tension rods)
Actually to convert the front end to 5 lug using the s14 parts, you only need the knuckle with the lugs. If you can't get the control arms too, you need to get s14 lower ball joints pressed into your lca, the shaft is different on the ball joints, but the lca's are the same, as are the tension rods. The biggest problem I ran into when converting mine over was getting some type of spacers for the knuckle's upper mounting bolts. The holes for the strut mounts are larger on the s14 than they are on the s13, so you will either need to retrofit some spacers(what I did), or drill out the holes on the strut(what my buddy did). Cheaper does not equal easier.
chaosli
Car: 89 nissan 240sx coupe FTW
99 mazda miata
93 bmw 325i RIP
ebay has some conversion hub for 150
