gumby74 »
https://forums.nicoclub.com/gumby74-u53716.html
Wed Mar 14, 2007 1:49 pm
First of all, you did match the rotor size to the calipers right? 26mm calipers to 26mm rotors or 30mm calipers to 30mm rotors. Secondly, assuming you do have a matched set, the pistons were retracted on both sides? I vaguely remember how difficult it was when I first replaced my rotors, but I do remember one pair of pistons needed a hair more compressing, then the calipers went on smoothly. Lastly, new rotors should be cut, shiny and ready to go out of the box. Always check the obvious first and good luck.
