need help with 240 clutch
chatodorifto
Car: White 240sx
Apparently my clutch has given out or it won't go into first without double clutching so I was thinking of bleeding out my clutch. The only issue is I don't know how and all my friends own Hondas so they're pretty clueless as well. Could someone help me out? Sorry if this thread has already been done.
WI_S14_Goldie
Car: 1995 Nissan 240sx SE, 91 240 fastback LE, 1997 kouki S14, DD = 93 Nissan Maxima
i think there's a thread some where in here about bleeding ur clutch system. Go to the DIY section and read up on some clutch installs. They usually have some info. But all u really need to do is unscrew the nipple from the slave cylinder and pump the clutch pedal. But i highly doubt bleeding ur clutch will do the job of ur clutch slippage...
