Need Help with 2 thing. Plz help asap
CJH
Car: S13
I need help with two things. First has been cover im sure 100 times, but the search feature doesnt work so, could anyone help me out.
1st- I have a S13 silvia front end and I do not have the blinker sockets that plug in there. I need to know where I can get some. There are two sockets in each blinker. One is a running light and the other is the blinker. Someone said I can use the stock one on the 240's, but I bought some online and they are way to big. It almost looks like the rear side blinker sockets might fit, but I dono. Where can I get some?
Blinker Houseing
Here is the one blinker I have. Its tiny
Here is the running light socket I have that has no harness clip
And I have none for the other side. Plz help
Thing #2 I need help with is a wireing diagram. DOes anyone have a diagram of the S13 ECU connector harness thingy. I would like to know what each wire that leaves the ECU goes to so I can depin it and simplify my harness. I would search but it doesnt work. Plz help.
Thanks
s13_chris
Car: 90 240sx Hatch
I don't know where to get some more light sockets. MAYBE, Nissan? They could probably parts match over and see if any other nissan's have that same one. Aaaand this should help you with the ECU diagram.
http://www.s-chassis.com/resources/wiki ... edirect=no
chaosli
Car: 89 nissan 240sx coupe FTW
99 mazda miata
93 bmw 325i RIP
your stock side marker will fit one of them
AZ89two4Tsx
For the corners, get a bulb holder that's a little small but just KINDA fits in there. Then wrap some rubber bands around that connector as needed. With enough rubber bands, you should be able to wedge it in there so it's not gonna move.
Pretty ghetto, but it works for as long as you need it to. Those connectors are really hard to find as they're JDM.
CJH
Car: S13
chaosli wrote:your stock side marker will fit one of them
So the rear side marker will fit one of them? Thanks.
^ and thanks for the diagram. Its perfect!
