1997D21 »
https://forums.nicoclub.com/1997d21-u159322.html
Mon Apr 04, 2011 7:22 am
I recently replaced a head gasket in my truck and the timing chain won't reach the cam sprocket so i now need to open the timing cover.
I can't get the crankshaft pulley bolt loose. As the FSM describes i put the car in 5th gear but the crankshaft pulley moves freely and i'm afraid of breaking
a valve stem if i try and put too much pressure on the bolt. and there are no holes in the front to wedge a screw driver etc to hold the wheel
steady. How do i hold the pulley still while i loosen the bolt?
Any Suggestions on how to keep the crankshaft wheel from moving while getting the bolt off?
Thanks
1997D21 on Mon Apr 04, 2011 2:43 pm, edited 2 times in total.
