need help with 1989 240sx problem
thatkidfrank
Car: 1989 240Sx
I have a problem with my 240sx she cranks but doesnt turn on but when i spry starter fluid in it she turns on then dies it has a new fuel pump and starter n new spark plugs and wires new cap n rotor n i put used injectors so im thinking its a bad wiring harness but idk
pan_duh
Car: 1990 Nissan 240sx
Have you checked to see if your heat temp sensor (engine coolant sensor) is good or clean or has good connection
thatkidfrank
Car: 1989 240Sx
No i have not but i will check that now but another thing that the harness is all over the place and has.some broken stuff n i think that sensor is one of them
S13 LS1
Car: 1989 S13 Ls1 Swap T56 Trans
HI I Have a 1989 Nissan 240sx fast back Shell I bought for $800 and I cant get the driverside door open I tore off the panel to find there must be a piece missing can anyone post a diagram of the mechanics
Gabe.S
Car: s13
Whats the model of the engine? Also where did you put the "used injectors" from and do you know for sure they work? Have you mixed the injector plugs? Also when you put your key in does it make a sound near the fuel pump?
thatkidfrank
Car: 1989 240Sx
ya i made sure not to mix up the wires n ya i can here the pump turn on i just found out im missing 2 relays one thats says n&p and the ignition coil relay like the spot where it sits is gone n i do have spark so idk
thatkidfrank
Car: 1989 240Sx
and the engine is a 2.4 sohc not the original motor the guy i got it from said that the original owners blew it
waxdnuggz
Car: 90 240sx hatch SOLD
91 240sx hatch SOLD
92 super sweet daily (freezing cold a.c., working ps and pw)
93 240sx hatch SOLD
94 240sx vert SOLD
If your spraying starting fluid in and it starts you know it's a fuel problem not a spark problem right there. Get a inline gauge to check the fuel pressure. Make sure the gas isn't stale and also did you install the fuel pump? I've seen a few times someone says the pump was replaced and never actually looked maybe they didn't install it right? Look to make sure the pick up is hooked up and the line from the pump is hooked to the ext. tank line. Also are you sure the tank has gas? I know dumb questions but sometime things are more simple then you think
