need help wiring my rb25det II into a 93 s13
cvcalitos1
Car: volvo 850 turbo, nissan 240 sx
i am new here and im woudering if someone has done this swap before i cant fiend good info on the rb25det II into 93 s13 all that i seen is about rb20 and the rb25 first generation. and it look diferent to me please help me...
Joe
only difference between a S1 and S2 wiring is there is no ignition relay.
cvcalitos1
thanks but the thing is i dont know how the s1 looks like at all im doing this on my own and im new to this new world of the rb engines..
whoareu
Car: 1993 rb25det s2 240sx vert
im not sure what your needing help with or what piont your at on the wiring. but i just practically finished my wiring. i did a s2 rb25 in my s13 convertable. all i can say is print off the wiring diagrams and the ecu pin information with wire color, and start from there. good luck and im me with specific questions if you have one.
cvcalitos1
whell im having trouble with the grey plug and the brown plug and also the wires of the big white plug on the insidei have alot of wires that i have no idea where they go on ......doy have any idea of the wire recuired for rb25 to start like the minimum for example the power for the ecu and coils just the bare minimun to start..i need colors and the color of the plugs if you can help me please...
whoareu
i can tell by your last post you have a lot of work ahead of you. you need to print off the wiring diagrams for both the skyline and 240sx. also you will want to know what wires are what colors, and start from there. also you need to seriously take it one staep at a time and figure one thing out before moving on to the next. also some good site that you should frequent daily are
http://www.240sxforums.com
http://www.skylineowners.com
http://www.zilvia.net
and http://www.skylineaustralia.com
i think those are the right site names. good luck. if you have a specific question. feel free to IM me
cvcalitos1
thanks brow you thing you can send me some picts of the wires of brown plug and grey plug and if posible the two plugs that go into the dash inside the car? i like to see the colors of the wires on bouth sides..i would realy apreciated men big time...and also let me see your car men just like to see how it looks. thanks alot..
