I realized the reverse polarity thing a while back while surfin the web for answers. does that just mean you take your factory plug that connects to the bulb wiring and switch it to plug in the opposite way? Im just confused about which wires i need to reverse to achieve reverse polarityAce2cool wrote:if it's not working, try reversing the polarity of the connections (take what you think is positive and switch it with negative) and see if that solves the issue. That's usually the problem with HID kits.
Okay thanks. Il go back and make sure I've done that correctly. Also I am using a harness, so that should not be an issue.Ace2cool wrote:^Yes. That's precisely what to do. The wires that connect to the stock harness need to be switched around. If that's not the issue, you might need to run a relay, as the stock fogs aren't meant for the kind of current draw that HID's demand.
Ace2cool wrote:Yes, but the aftermarket harness is using the stock harness, correct? The STOCK harness isn't meant for high current draw like HID's need.
Ace2cool wrote:No, what you described is a relay kit (which most people don't buy; they like plug and play).
Here's a general overview of how the kit should work: The kit will be receiving constant power from the battery, and opening the circuit at the relay. It will then receive an "on" signal from the stock harness when you turn the fogs on. (Mind you, the fogs only turn on when the low beams are on. No other configuration.) The "on" signal tell the relay to close the circuit and supply power to the ballast, supplying power to the bulb. Are you sure you have a good ground? Clean connections are a must with HID's. If all else fails, bust out a multimeter and measure voltage.
lol no actually. ddm is usually quality. but its not impossible, and it seems like that may be the only explanation. im just gunna take it to the local shop soon...let them determine whats upAce2cool wrote:You can ground one, but it's the same as connecting to the negative side of the battery. The negative side of the battery, if you look closely, is directly connected to the firewall directly behind the battery, then to the transmission. So grounding it to the car would be the same as connecting it to the negative side of the battery.
You have considered the possibility that they sent you a crap kit, haven't you?
oh damn i had no idea. ill check it out thanks.Ace2cool wrote:I've heard many cases where DDM has sent bad bulbs. Check Z32 General out. There's a thread on the first page about HIDs, and page 3 of that thread alone has 2 people that got bad bulbs from DDM.
