Need help.... which driveshaft???????
sleepyeyes
Car: '93 240sx Fastback
Okay i really need to get this swap done by the end of this week, let me tell you what ive done...Ok, i have a 91 body, was automatic but ive done a manual swap, i have a 95 ka, 95 transmission and 95 drive shaft.What drive shaft do I use? The 95 transmission didnt fit, the bolt that hold up the rubber in the middle were way off. So do i use a 91 driveshaft, or do i have to go all 91-94 parts and the only thing i use 95 is the ka? Someone plz help, I need the car to be running cause im movin out on the 1st. Thnx
NISTECH
you should be able to use the 95 engine and trans. but you may need to use the shaft out of your 91. does the splines in the output shaft match that of the diveshaft yolk??
sleepyeyes
NISTECH wrote:you should be able to use the 95 engine and trans. but you may need to use the shaft out of your 91. does the splines in the output shaft match that of the diveshaft yolk??
Let me look into the 91 driveshaft thing
