need help where to get steering wheel hub
david200095367
Car: 91 fastback 93 coupe w/s14 sr20det 98 s14 kouki
i have a 91' 240sx hicas model and i got a momo steering wheel and need to find a hub for it. momo and sparco say that their hub wont fit the hicas model. does anyone know where i can buy a hub for the hicas model?
thanks
240DRFT
only thing i can think of is maybe ebay
Mixmastamunkh
Car: nissan 240sx
bah, that's bull$hit. i have a hicas model with a momo hub adapter. i don't know what those hoebags are talking about.
justmerging
Car: 07 Versa SL w/CVT Cuz I'm lazy
If you have a hicas with a momo hub adapter, then your hicas no longer works. there is a sensor in your steering column that measures steering input angle. Without this sensor your hicas system renders itself inoperable.
The only adapter available that retains this sensor is the nismo hub. you can get it from http://www.raretrick.com but it is fairly pricey. I don't know if it will work with the momo steering wheel though.
david200095367
does ur hicas still work?
justmerging
yes it does
Mixmastamunkh
Car: nissan 240sx
that doesnt make sense..... i HAD a grant steering wheel that the previous owner installed, it had a grant 5 lug hub and i got the "Grant to momo" hub adapter from cardomain.com shop. it was just to convert my grant steering wheel to a momo one because momo uses 6 lug. or whatever. anyways my hicas is still intact. are you sure that is all completely correct?
david200095367
so what is the truth, will any hub work? i am a little confused.
justmerging
without the sensor in the steering wheel the hicas system will disable itself. the previous owner either removed the sensor or adapted the grant hub to work with the sensor.
the sensor has 2 prongs that stick out and interlock with the stock steering wheel. for an aftermarket hub to work it would have to have holes in the hub to accept these prongs. without these prongs the hicas system does not see a steering angle input and will not function as it thinks the car is going straight all the time. If you pull off your stock steering wheel you will see what I am talking about.
david200095367
so would i be able to modify the hub to work for the hicas?
justmerging
yes you could, you just need to measure where the sensor is after you take off your stock wheel and cut the appropriate holes in your new hub. beware that the material used in the hub is very thick and very difficult to cut through with any kind of accuracy.
Ajax
Car: 1991 240sx SE
2010 Mazda 5
I encountered a similar problem. I had already disabled my HICAS, but my horn does not work. Does anyone know of a way to ghetto-rig the horn to work with a standard momo adaptor?
fatboy
Car: s13
Ajax wrote:I encountered a similar problem. I had already disabled my HICAS, but my horn does not work. Does anyone know of a way to ghetto-rig the horn to work with a standard momo adaptor?
a big problem i see when people mess with their steering wheels is damaging clock springs.....
