Afrikaaner »
https://forums.nicoclub.com/afrikaaner-u143971.html
Mon Aug 08, 2011 11:29 am
so now that i finally took the time to get my car back on the road, i am reminded about the fact that i have some suspension or brake issue(s), i'm not sure which. symptoms i've noticed:
*brake shudder like a warped rotor, even when i had on brand new rotors/pads, though the new goodies seemed to mitigate the issue a little for a while
*when i ride over uneven pavement (like a wide crack running in the direction of the road) the car shimmies to one side or the other, and kinda goes back and forth
*when driving at highway speeds, i get some vibration like i threw a wheel weight or i need an alignment/balancing
so i was wondering if you thought my idea of it being a worn kingpin was outlandish or if you had any better ideas. i had gotten the surface the rotors sit on cleaned when i got an alignment a while back, one or both of which helped significantly for a short while, but after a few days it was back to the same old nonsense.
your thoughts?
