NEED HELP ! Weak engine start up ???
Hookm36
Car: 2004 G35 coupe
OK, so I have a 2004 G35 auto, has 50K miles, over the past 3 weeks, I have noticed that when I start up the car (doesnt matter what time of day) that it kind of hesitates to start, the starting sound is weak, not as bold as it was before.............NOW, a buddy of mine has the exact same car, an 04 w/ about same mileage ect......he is experiencing the SAME EXACT problem........I dont know what it is?
we both installed a JWT pop charger and z tube at the same time, but it was back in like September i think......we have not re-oiled the filter, could this have anything to do with it ?
Thank you for your help!
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
Weather, Starter, Spark Plugs, Battery.
The popcharger shouldn't be causing this.
infinitgkid
Car: '06 Infiniti G35 Coupe
Sentientbydesign wrote:Weather, Starter, Spark Plugs, Battery.
+1
I'm thinking spark plugs, thats where I'd start when checking...
Good Luck
telcoman
Hookm36 wrote:OK, so I have a 2004 G35 auto, has 50K miles, over the past 3 weeks, I have noticed that when I start up the car (doesnt matter what time of day) that it kind of hesitates to start, the starting sound is weak, not as bold as it was before.............NOW, a buddy of mine has the exact same car, an 04 w/ about same mileage ect......he is experiencing the SAME EXACT problem........I dont know what it is?
If you've got the original battery replace it. Probably a weak cell?
Telcoman
G_whizz
Car: 2010 G37 Coupe Sport
infinitgkid wrote:+1
Good Luck
+2
Start with the plugs. How does it idle once it gets going? I am more then positive it's not the popcharger.
telcoman
infinitgkid wrote:
+1
Good Luck
Plugs should be good for 100k miles
Telcoman
G_whizz
Unless theres an oil leak...
Hookm36
Car: 2004 G35 coupe
Guys, so I just was gonna leave and head back to work.......guess what........CAR WONT START
Its gotta be battery right ?
Sentientbydesign
96 I30 - Sold
Mostly likely the battery.
But it could be a corroded wire or a short circuit somewhere.
When you turned your car on in the past, did your interior lights dim?
If so, it's definitely the battery.
If your G is stick, you should be able to push it and turn it on, though I've never tried it. If it's an auto, get a jump start and drive it to somewhere to get a new battery (don't turn it off until you get a new battery).
Tampa G35 Sedan 6MT
Car: 2006 Infiniti G35 Sedan 6MT Black w/ Premium & Areo Pkg
1989 Jeep Cherokee 4X4 Lifted and Old School!
Still might be time for new sparks plugs...
But yea it is the battery. Now if your car dosn't stay on once it is started... well then you have an alternator problem!
But you can change them out yourself in about 1-2 hrs. they only cost like $100 bux or so!
DJ
G_whizz
I agree with the fellas...sounds like a battery.
For the love of God...please don't let a BMW owner see you pushing the G.
Tampa G35 Sedan 6MT
G_whizz wrote:I agree with the fellas...sounds like a battery.
I can see it now on TV as a BMW advertisement A NICO member pushing his G35 to get it started. BMW owners never have to do that... We just turn a Key
DJ
Sentientbydesign
96 I30 - Sold
DJ
I just got "followed" by one of those Bimmer owners. I was driving to the post office to send off some wires and as I signal for a lane change, I see a 5 series coming up fast into the lane I want to be in. He follows me into a turn lane, down the street and when he realises I'm going to the post office, he decides to flip a u-turn and break traction.
I wanted to follow him, but I had better things to do and I'm still breaking in the engine.
telcoman
Sentientbydesign wrote:Mostly likely the battery.
Everyone that drives a stick should give it a try. Next time you are heading down a hill with no traffic pull over to the right & shut off your engine. Place transmission in 2nd gear, turn on ignition & let vehicle begin to roll down hill with your foot on the clutch. At 10 MPH or so let out the clutch & the vehicle will start. With a weak battery always park in a place where its possible to start the vehicle as described above. Also its a good idea to carry jumper cables.
Telcoman
Hookm36
Car: 2004 G35 coupe
took it to the zone....battery is low....gonna add some distilled water to the cells, there was very little in there...
C-Kwik
Telcoman
Or buy a emergency starter battery unit. I keep one in the Titan just in case I do something stupid like leaving a light on. Thought, I think I've used it more often to help other people than myself...
WhiteyClay
Car: '03 G35 Sedan
I would check fuel pump....just another thing you can check while other stuff dont help....
Jacko3
Jacko3
I agree!
Tampa G35 Sedan 6MT
Yea I thought the water would be low... That is normaly what causes a bat to go bad!.. I should have said something earler but forgot
make sure you use 100% distilled...
DJ
telcoman
Hookm36 wrote:took it to the zone....battery is low....gonna add some distilled water to the cells, there was very little in there...
Well if the battery is 4 or more years old, it is possible not all of the cells will accept a full charge?You will need to purchase a battery hydrometer to check the specific gravity of each cell. I believe the full charge reading is around 1280 but it will tell you on the float in the hydrometer. You may very well end up needing to replace your battery because cells without sufficient water for a long period of time are probably near end of life. Battery's tend to fail at the most inoppertune times. Nasty weather, middle of the night, etc.
Telcoman
BrandAidDesignG35
Car: 04 Infiniti G35 Sedan
Battery for sure, I'd get a new one, Good Luck!
lol
turnitdown
Car: 2004g35x
Boy is that true. My 04 was getting slow on start ups last summer and I put in a grounding wire kit. G started up peppy till this summer, so when I am changing the plugs, I will definetly change the battery.
kmckis1029
Car: 2016 Q50 RS400 AWD
2010 G37x w/Prem, Nav, & Wood (sold)
2005 G35x w/Prem C (traded in)
TeflonG35
Car: 2003 G35 Sedan
at 50k It can't hurt to change the plugs anyway.
