Need help w/ removing emissions crap.
daniel240
Car: cars/motocross
I know this isn't exactly kat related but i know many of you have done this so i figured i could get some help here. I want to remove all the emissions stuff that i dont need, but im still not sure what all stays and what i can move. Ive searched and looked at my FSM but im still confussed. Please help me out. I took a few pics so maybe you could tell me what stays. thanks.
Structure240sx
i'm not too keen on the OBDII stuff but i know a few things you can remove
EGR (if you havent already)carbon can behind the drivers headlight. i used rubber caps for everything connected to this
all the stuff you are pointing to in the picture im sure you can jsut rip out and cap off. im not sure though if you are suppose to do anything with the plug or just leave it hanging.
what you do need to keep is the IACV and the pvc system under the intake manifold
DirtyKA
Car: S14 KA-T
The little Mini BOV looking thing on the intake manifold is the EVAP Purge Control Valve iirc...I pulled that off, and it has a line running to the intake mani, which I pulled off and capped.Then just follow the other big line coming off of that back to a hardline running along the frame rail and pull it off and leave it open.Then the 2 sensors on the strut tower are the BARO and absolute pressure sensor switches I believe, you can pull those off and follow the vacuum lines back to the intake manifold and cap them.Then just leave the sensors plugged in and tuck them away... the one mounted lower on the strut tower actual screws right into a hole on the lower/back part of the intake manifold, and you can zip tie the other sensor somewhere..And then on top where the fuel lines are.. The whole spider web of hard lines and sensors and what not, I just yanked that whole thing off and ran a feed and return line... And I bet if you leave the sensor plugged in and just tucked under the intake mani it wont throw a code..And if you pull the EGR off you can solder in a resistor to make it not throw a code...
After your done with all that stuff, if you want to clean up your engine bay even more you may want to run the harness under the intake manifold, I did it in my 96 and it looks alot better.All you have to do for that is trim back the individual injector pig tails from the main harness, rewrap it, and then run it under the intake mani and out the front..
Tictakman
got any pics dirty??
Zak
DirtyKA
Car: S14 KA-T
Tictakman wrote:got any pics dirty??
Zak
I dont have any at the moment, but I could see if I could borrow a digi and snap some pics of it for you guys... Although as the name implies, my ****s dirty. hahaha
daniel240
Car: cars/motocross
hey thanks a lot. I will start pulling off the things you said. Im sure I will get stuck again. I just dont want to rip anything off that i need. also where do i put in that resitor?
DirtyKA
Car: S14 KA-T
Alright.. Grabbed some pics for you guys..
Heres the first pic, just the passenger side of the engine with that stuff removed and my harness tucked under my intake mani..The line I circled in red is something that I can remove, I just havent had the time... Its just going into a vacuum source and is plugged on the other end, Im just too lazy to go in there and put a cap on it since its kind of difficult.. 2nd pic shows where some of those vacuum lines that are ontop of the intake manifold run to, Im using 2 of them, one for boost gauge source and one for BOV, the other one I capped off..And this 3rd pic shows the harline which the EVAP purge control valve ( thing that kinda looks like a dsm bov ) runs to... I still have a bit of work to do on the harness.. I want to try and hide some more things and clean it up a bit..And it would also look a bit cleaner if I trimmed the fuel feed/return lines down a bit and tucked them away but once again, im pretty lazy. haha
northstar ninja
Car: 74 260Z, 92 240sx hatch.
i miss having a de...-g
Projex240
Car: Dogs , My RIDE
i removed all that crap. I took it all off and unhooked the sensors too. Itll throw a code, but it wont affect the way the car runs at all.Also, the evap canister wont hurt anything =, itll juts make the pressure in the gas tank build up if you cap the line off. If you leave it open its fine, but i would go welding under the hood.
-Josh
fenderfatstrat6
Car: 240sx s13 hatch
so what did removing all this stuff gain in the way or mileage or power increases?
kouki_hmongster
Car: Want 97 kouki
Would it be the same for all 240sx?
fenderfatstrat6
bump
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
just for a little more visual stimulation from my 95 manifold without the secondary butterflies aka swirl valves
I removed Everything except the AICV
With Emission..
Without..... so much space and cleaner looking
WDRacing
Thanks homie...
You guys need to look at when this thread was made...2005. Daniel240 doesn't even post here anymore.
To answer your questions, you don't gain anything by removing the emissions crap. You simply clean up the intake. You also have to atleast plug the egr tube hole after you remove the tube.
WD
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
HAHAHH slaps self in the face
fenderfatstrat6
so isn't removing it only a waste of time ?
