need help verifying connectors
NissanTouge87
Car: 1992 CA18 S13 hatch, 1992 pignose nissan pickup
This technically has nothing to do with the CA swap, but since we've all messed with our wiring and non of the cars seem to run, ill post it here since i could probibly get the most help.
As some of you may know, after i got my CA moving, not really running, but atleast moving, my body harness caught on fire. After getting a used harness from an 89 LE and splicing the circuits and replaceing the fusebox, putting the harness in the car, i now how 3 plugs that i dont know where the hell they go.
Ill explain where and what the plugs are and link you to the photobucket where you can see my crappy camera phone pics.
Plug 1: Its a brown 2 wire plug under the steering column. It has foam padding around it and it originates from the lock cylinder, i believe the FSM called it the Key Switch. I cannot find the female plug.
Plug 2: This along with plug 3 are located in the drivers kickpanal. Both plugs are on a stand/loom of wires that has the part number and barcode tag on it. Plug 2 is a 16ish wire plug with a rubber condom/boot around it, its on the very end of the loom/strand..i cannot find the female connector
Plug 3: Same location as plug 2, but this is a 2 prong plug, thats white, along with plug 2. It looks like it should clip onto on of the many black boxes in the kick panal, i just cant find the one it goes to
Now the ****ty picshttp://smg.photobucket.com/alb...plugs/
NissanTouge87
anyone?
i need to verify if these plug into anything before i put on the battery and see if my lights and wipers and stuff works..so if anyone can help?
