Need help ...URGENT!
Xdisaster240sX
Car: S13 Hatch, R32 GTS4
My wife ans I are in the middle of looking for a new car and the S13 crapped out on us. Its our only car right now. Heres the problem...
It revs really slow and it takes a good 2 minutes to get upto atleast 40mph. It also sounds like its gargling or bubbling in the exhaust. I dont know how else to put it. There is also a misfire. I have checked the compression in a four cylinders which turned out being about 150lbs, Replaced the Spark plugs,Wire, distributor cap, I did the timing and replaced the EGR valve. The car continues to burn rich, smoke,bog, and go as slow as a Nalas dating career :chuckle: James at J/E and Brian at MidAtlantic both want about 150 to plug it in but I dont have that kind of money at the moment. :cry:
Oh I forgot to mention that I changed the Maf sensor, Throttle control sensor both twice.
Last edited by Xdisaster240sX on Tue Aug 10, 2010 3:59 pm, edited 1 time in total.
92CONV
Car: 89 240sx hb
90 240sx hb rip
92240sx conv and swaped
have u read ur ecu u have a self diagnostic mode on it. maybe o2 sensor?
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
MAF? TPS? They do funny things when they start sending the wrong signals.
Try Seafoaming it.
Xdisaster240sX
breadbox wrote:MAF? TPS? They do funny things when they start sending the wrong signals.
Try Seafoaming it.
I replaced it but I didnt seafoam it. Could that really make a difference?
s0m3th1ngAZ
Car: 96' Miata
2014 Focus ST
Are the maf and TPS you switched in both new?
Xdisaster240sX
no Junk yard but I grabbed aalot of them and changed them several times.
92CONV
Car: 89 240sx hb
90 240sx hb rip
does it run light s*** all the time or when it worms up. tthinking about it i had a problem with my older ka whent threw a lot of new sensors doing the same as u and turened out it was the coil pack
Razi
Car: Moo
So, have you checked your ECU error codes?
AZ89two4Tsx
Could be a really bad vacuum leak. Check all of the lines and that black plastic box thingy. Mine had a hole in it once and ran like sheeeeet.
Dittoz7
Car: 1997 2f0WtY SE!
Founds a lot like mine except for the acceleration part.
I'm thinking FPR, Fuel pump or Injectors.
Joe
you guys are shooting completely blind. you cant troubleshoot like that.
first check for codes with the ECU.
