rb25240driver »
https://forums.nicoclub.com/rb25240driver-u190403.html
Fri Sep 09, 2011 8:28 am
what mods do you have installed? if you dont have any then why the e-manage. if it were me and i didnt have any modest mods,ie, bigger injectors, turbo, etc, then drop the e-manage for the time being. the stock ecu should suffice just fine for the time being. it just makes it one less obstacle to deal with when getting it to run. once its running decently, then wire up the emanage, shouldnt be hard to do that. also, i am completely unfamiliar with your mechanical knowledge, but for the sake of argument, im going to go with not alot, not trying to offend, but you should also check for vac leaks, are you running a recirc blowoff valve or is it atmosperic meaning it just dumps it out in to the where ever you have it pointed?
