Tictakman »
https://forums.nicoclub.com/tictakman-u2357.html
Mon Dec 20, 2004 7:41 pm
should i mess with the low map at all just just the high pretty much? also, i was thinkin just to be safe to retard the timing a little bit more. would that hurt anything besides performance? right when i turn on the car (previously on) the LM said RICH on the screen. i dont know if it was the intial start up or not but that went off within a few seconds. the the numbers began to rise to around 17 at idle. when id give it some gas it would go down to about a 12 or lower so i guess im in the ballpark just need to add some fuel in the idle and some in the rpm band. that sound correct? also, im running 93 octane. thanks structureZak
