Need help tuning my CA18DET
S13king
Car: 1989 S13 Hatch, 93 S13 coupe, 94 supercharged thunderbird, 98 Accord
hey i just got my CA18DET but i need to tune it with my SAFC II. the motor has a T28, 440cc injectors, greddy FMIC and piping, Equal length turbo manifold, KA24E MAF, and Trust Downpipe. Just need to know what i should set my SAFC to so i can get it running. i did search on the site but it is different on each setup. Any help is greatly appriciated thanks.
mbmbmb23
S13king wrote:hey i just got my CA18DET but i need to tune it with my SAFC II. the motor has a T28, 440cc injectors, greddy FMIC and piping, Equal length turbo manifold, KA24E MAF, and Trust Downpipe. Just need to know what i should set my SAFC to so i can get it running. i did search on the site but it is different on each setup. Any help is greatly appriciated thanks.
zer...45721
S13king
oh sorry i guess i should have specified. the SAFC II is hooked up and working. i just need to tune it to get the car running. i just cant get it to run. the guy i bought it off of messed with the damn thing and it died. he worked on it for 30 minutes but never got it running
bentvalves
Car: 89 Silvia K's
hmm would it keep your car from running entirely, I dont think so.
I could be wrong however, I dont have any experience with safc.
perhaps your plugs got fouled while the dood screwed with it?
mbmbmb23
From what I've seen inheriting a car with SAFC is a gamble, you never know how much of a hackjob was done installing the thing. I think if you posted the current settings in the SAFC unit we could better help you.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Hot wire, 2 in 7 out (n62 maf) 7 in 7 out (CA maf) no clue (KA-E maf)
4 cyl
TPS 0-5v
Start with a -12 or -15 or so around the low RPMs and gradually ease up on it until you are about -5 to -7 at redline and see if it won't run. It should.
S13king
thanks for all the info. im going to check the plugs and try those settings. i would post the current settings but the cars battery died while my friend was tryin to fix it so it is all set to 1 or 0. Again thanks for the info
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
ks13 wrote:hmm would it keep your car from running entirely, I dont think so.
agreed. less he accidently disengauged the injector harness from the ECU wiring harness.
S13king
ok tried some the settings i have found but nothing works. finally got time to pull the plugs today they are fouled. found the old plug in the car they are fouled aswell. going to replace my plugs and maybe get a Z32 MAF
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
S13king wrote:ok tried some the settings i have found but nothing works. finally got time to pull the plugs today they are fouled. found the old plug in the car they are fouled aswell. going to replace my plugs and maybe get a Z32 MAF
Hey hey, no random mods yet! finish what u started and get it running before chucking new mafs at the car
hope yo get it figured out, good luck!
S13king
its not a random mod. i have read that the KA-E MAF runs the engine lean in the higher RPM range but i cant afford that yet. i think it is just the plugs i havent put them in due to snow and school but they should go it tomorrow. thanks
float_6969
NO, it runs lean in the upper RPM range if you don't correct for it somehow. You have an SAFC, so you can correct for it. The Z32 MAFS is overkill for your setup.
S13king
float_6969 wrote:NO, it runs lean in the upper RPM range if you don't correct for it somehow. You have an SAFC, so you can correct for it. The Z32 MAFS is overkill for your setup.
oh ok then i read it wrong i guess. sorry. well i got it running. but the the number 2 coil is arching onto the vavle cover. i have tried to readjust it but it does the same thing. anyone else run into this problem
CakeEater
Car: '93 240SX w CA18, '08 Titan Pro-4X
Umm...do you not have the red silicone boot on the coil?
S13king
CakeEater wrote:Umm...do you not have the red silicone boot on the coil?
yea i do. i started it up and popped the hood and it was lighting up the engine bay so i immediatly shut it down
float_6969
Pull the boot off and look at the end of the coil. It should have a black, ceramic sort of looking thing that is spring loaded (you can push it in and it will push back out). Often that spring-loaded contact will come out and then the coil is no longer in contact with the spark plug, hence the arcing.
S13king
thanks i will do that
rovert
Car: 1992 Nissan Silvia
I dont want to thread jack, just a question that goes with his setup. Will an SAFC suffice with that setup? I have a T25G, 450cc, Z32 MAFS, fuel pump etc and I cant get an ECU tune to work for the life of me. Would I be ok switching to an SAFC like him? Thanks.
