rmezz13 »
https://forums.nicoclub.com/rmezz13-u82416.html
Sat Mar 15, 2008 4:43 am
I'm rockin' the Injen CAI. No bypass, and puts the filter infront of the radiator (most are behind the radiator (Nismo). I don't get my car out if the road is wet, so i am not worried about getting a bypass on it. If this is your concern in a cold air intake then something behind the radiator should suite you. The plastic skid plate (under your car) should keep excessive water from splashing into your pipe, and a bypass shouldn't be needed. Injen CAI = $265 most places online, 7+whp increase.
For other intake mods you could look into a throttle body spacer, and plenum or plenum spacer.
Kinetix V+ Plenum 14+whp increase, 3 pounds weight reduction $300...Helux Throttle Body spacer, weighs less than 1lbs. 8+whp, $80-$90...
For $600 you can really wake that car up, and you can ad them as you get them, all bolt on, no tuning required.
