need help, transmission
kainvamp
Car: '91 Sil80 w/ SR
ok, so i was 1 block away from home and when i went to push on the clutch it went right to the floor. At first i though ok probably master or slave cylinder, but i look under the car and the piece that sticks out of the transmission that the slave cylinder presses on his just dangling out the side. How do i go about fixing this, do i need to take my transmission off? I couldnt get a good look yet because im parked on a hill and i gotta get it flat before i go jacking it up. If this ever happened to anyone else let me know what you did.
E7-S14
Car: ess 14 foo!
dam.. you gotta take that bi*ch off to fix it..
Have fun.. it was a pain for me to even get on the god dam T/O bearing.. all 5 times ive had to do it...
and no. mine has never fallen out.. the times ive had to put it on were during transmission and clutch swaps with my and a few other 240s
believe its called a clutch Fork.
kainvamp
s***, think im gonna need any new parts i need to order or should i be able to get it back in once its off? i dont know why it would pop out lol
driftneil
Car: A pile of cars.
kainvamp wrote:s***, think im gonna need any new parts i need to order or should i be able to get it back in once its off? i dont know why it would pop out lol
It's only held on by a sprig clip, and is pretty rought to put on. What I had to do was pull the boot that the fork goes thru, then push the pin on, then install the boot again. It just sits on a ball pivot, then the spring sits in the channels of the pivot, then clips into the sides of the fork. Good luck man, it's a s***ty job.
kainvamp
well my buddy is coming over in like half an hour, so hopefully we can get it done right lol just when i think everything in the car is finally not broken haha
kainvamp
ok i kinda ran out of light tonight, but i got up to where everything is unbolted and everything unplugged. I'm trying to pull the transmission back but the housing is hitting the firewall, how far back does it need to go before it will drop down?
driftneil
kainvamp wrote:ok i kinda ran out of light tonight, but i got up to where everything is unbolted and everything unplugged. I'm trying to pull the transmission back but the housing is hitting the firewall, how far back does it need to go before it will drop down?
About 6 inches, your best bet is to put a block on your oit pan and jack up the front of the motor. You can also spin the trans, so the starter bump is facing down. The tunnel is kinda tight on the s13's.
kainvamp
thanks for the advice man, hopefully i get it done tomorrow haha
driftneil
It's only a days worth of work, you should be good. The hardest part is putting it on.
E7-S14
Car: ess 14 foo!
driftneil wrote:It's only a days worth of work, you should be good. The hardest part is putting it on.
Out and in, in 3 hours. on our backs.clutch swap included.ha. we've had practice.. but it sucks a** everytime.just remember what bolts go where. it suck having to figure it out after.
driftneil
s*** I'm horrible for remembering. I put all the trans bolts in the order they come out, in a piece of cardboard. Then you can't forget!
kainvamp
well an update, its not that the clip came off that ball...the f***in ball snapped off...
Modified by kainvamp at 9:40 AM 5/16/2009
kainvamp
how the f***...
kainvamp
nvm i guess i can just buy a new clutch fork pivot
kainvamp
just gotta wait for my new pivot to get here, anyone have any more tips on getting the trans back in, that thing is hard as hell to get out. I was thinkin bout hitting the sides of the fire wall in just a little, seems like 1/2 and inch and the b**** wouldn't rub on it
E7-S14
Car: ess 14 foo!
i lay on my back and man handle the transmission in.this way you can spin it side to side to get it in.
also have the motor jacked up a bit using a block/ or piece of 2x4 on the oilpan to free up some space between the top of the trans and the transmission tunnel
driftneil
E7-S14 wrote:i lay on my back and man handle the transmission in.this way you can spin it side to side to get it in.
Ditto on both, don't smash your tunnel.....No need. Loosen your motor mounts as much as possible without taking the nuts off, and jack the front of the motor up. You can also have someone put a 27mm socket on the crank nut. While you push the trans in, have them turn the crank. It helps to line the splines up.
kainvamp
got the pivot fixed, trans finally back up in car. Man that is a pain in the a** lol just gotta tighten it up and put the drive shaft back in tomorow. Went out and bought a ratchet strap, after pulling the engine back with it it was so much easier. Thanks guys for all the tips.
Being without my car for a week sucked hard lol im gonna be so happy tomrow when i can drive again!!!
E7-S14
Car: ess 14 foo!
took you a week to do that ha?
kainvamp
no lol the part just came and my friend came over and we did it this afternoon in like 2 hours. after i used the ratched strap it went right in lol
