Need help trans problem
RELLQ
Car: 1996 q45
Alright this morning I changed my spark plugs and drove to work right after, the car drove wonderful. Tryin to leave the job and the shifter is locked in park and is unable to shift to drive. Any fast ideas before the tow to the shop?
96 q45 145.xxxthanks
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Do you mean the shifter wont move?
RELLQ
Car: 1996 q45
Yeah my shifter is stuck, I usually hear a slight tick from shifter when I press the brake but not now. It doesnt want to engage drive
elwesso
2007 BMW M Coupe
Just take the shift lock release plastic plate off thats just to the right of the shifter..... Then you can stick something in there (key, screwdriver... i personally use a golf tee) and it will release the shifter.
That will at least allow you to drive the car... We can diagnose from there.
RELLQ
Car: 1996 q45
Alright I released the shifter via shift lock and drove home 18 miles. I ran through every gear and it still shifts normalor maybe alittle slow. Got home shifter is still stuck in the park position
qship96
Car: 1996 Infiniti Q45
shifter is controlled by a switch that is connected to brake pedal- look up where brake pedal attaches and check alignment and contacts of the switch to start.
elwesso
2007 BMW M Coupe
Thats what I was going to suggest. However I have a hard time believing coincidences..... But i also dont see how someone could have messed something up while doing the spark plugs to make this happen...
the brake switch is cheap from Joe, id just replace it.
