stojakovic wrote:Yesterday I got my Q dead on the way home. I had to call the road assistance and wait a long windy Sunday afternoon.
I got this car for 1 year, and it runs great till last week. I want to figure out the problem so that I can take it to the right place to service.
I will state the problem below.
Last Monday, I found my check brake light on and TCS off light on. I have new brakes changed last summer, and I do not have more than 2000 mileage on it. I remember that before I change the brake pads, the light was on, but after that it was off. However, the message from the right conner of panel still said brake pad worn. The sensor may be damaged.
Last Wednesday, while I play audio, it suddenly stop playing. The other light are gradually off. The battery was out off power and I managed to get a new one on Thursday. It runs again and the problem is that the the message adds low battery charge in addition to brake pads worn.
Then on Sunday, my Q dead again. First I noticed that my speed pointing to 0, and then I prepared to right lane. I can still accelerate for several minutes, and then accelerator dead. I had to stop on the road side and find a police to light a flare.
My friends came with the jump start cable, and my Q can start engine with cable on. Once the cable is removed, the engine is off immediately.
What I guess is that there maybe computer problems. The full battery can work means the connection is OK. The car cannot charge battery back. I am not sure there is a fuse for charging. Actually, I think the connection for discharge and recharge should be the same cable.
I will let my battery charged again to test.
I heard that it may be caused by engine problem. I am a little worried.
Can someone give me some idea about my problem?
Sounds like a bad alternator. If your brake light flashed periodically leading up to now steady bright, you need to change the alternator. To be honest, you just need to change that damn alteranator... period. If you plan to do the job yourself, you will need to drop the ac compressor with all lines still attached to to get to the alternator which is directly above it. Do not try to remove alternator from above. Drop compressor first. All work performed from below.
Good luck and let us know if you need assitance. Good thing is, you have one of the best support forums in the world.
PS, if you fry the ECU, we have more....
...Drew....
Звучит, как плохо генератора. Если ваш стоп-сигнал .. "периодически до сих пор устойчивый ясный, вам необходимо изменить генератора. Чтобы быть честным, надо просто изменить это чертовски alteranator ... периода. Если вы планируете делать работу самостоятельно, Вам придется отказаться от сети переменного тока компрессор с линиями все еще придают добраться до генератора, которые прямо над ним. Не вынимайте из генератора выше. Падения первого компрессора. Все работы снизу. Удачи и сообщите нам, если Вам необходима области оказания помощи. Хорошее дело, у вас есть один из лучших форумов в поддержку мира. PS Если Вы мальков ЭКЮ, у нас больше ... ... Дрю ... b
Modified by DrewQ45 at 12:00 AM 3/17/2007
