need help! think i messed up :(
evoixwill
Car: s14, evo 9
This is my problem i have a 96 s14 with no motor and transmission, i have two s13 trannys i know they will work i just need to put in crank angle sensor and swap out speed senor i think. my real problem is that i ended up buying a s13 ka dohc motor. i know theres some differences between the motors what do i have to do to drop in the s13 ka dohc in my s14?
ShouldaHadaV8
Car: 92 hatchback 240sx, j30 diff, TIEN tie-rods
hmmm i believe you need the s14 harness , ecu, (distributor, throttle body, and manifolds). search it i may be forgetting something. and let me know i have all that stuff except the dizzy, if you have pay pal, or if you live in florida, i will sell the intake and exhaust mani. and the throttle body for $75 you cant beat it
evoixwill
Car: s14, evo 9
i still have a harness and if i get the distributor, throttle body, and manifolds will everything connect right up when i drop the motor in.
sounfds like i might have to buy those parts from you
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
s14 and s13 harnesses are diff. the s14 pulls some of its power thru the engine wiring harness. s13 in s14 will need intake manifold swap so all the sensors will work. s14 harness will also be needed so body plugs will mate up
evoixwill
Car: s14, evo 9
so as long as i swap the manifold and get the harness to fit up ill be good?
evoixwill
Car: s14, evo 9
ShouldaHadaV8 ill but that setup off of you.
ShouldaHadaV8
alright i will have my old lady or my brother show me how to do this pay pal stuff and i will get back with you asap
s13drifter88
swap manifolds and engine harness... plug and play
evoixwill
Car: s14, evo 9
s13drifter88 wrote:swap manifolds and engine harness... plug and play
so ill need the s13 harness
s13drifter88
use the s14 intake and s14 wiring harness so the s13 engine will work
evoixwill
Car: s14, evo 9
ok thank you for your help i feel much better now. so now ill have to find the intake manifold.
s13drifter88
search this site, get on ebay and ill even check in all my spare s13/s14/s15/ca/ka/sr/rb piles and see if i can dig up a manifold. i may have one which i sell for 50 plus shipping if i have it. if u find one elsewhere lemme kno
evoixwill
Car: s14, evo 9
s13drifter88 wrote:search this site, get on ebay and ill even check in all my spare s13/s14/s15/ca/ka/sr/rb piles and see if i can dig up a manifold. i may have one which i sell for 50 plus shipping if i have it. if u find one elsewhere lemme kno
well let me know if you have one.
s13drifter88
k
