ok thank yougumby74 wrote:If it is a 5 spd. check the clutch interlock switch.It sits somewhere upstream of the clutch pedal, looks like a small button sticking out through a nut. Disconnect that, and jump both sides of the plug together with a piece of wire. Do this on the plug itself not the sensor.If it starts, you found your problem, if not, check all fuses and connections. Battery terminals, grounds and starter wiring.
