yup. its like 4 bucks at the dealership. i need to pick one up, its commonly referred to as a brake light switch groment.irocsx2002 wrote:Most likely the issue is the pedal assembly sensors. There's a rubber stopper (2 i believe) type piece that pushes a sensor in where the pedals are located. It is pushed it when when you are not on the brake's or any other pedal. etc.
Over time it gets hard, cracks, then breaks off. This causes the sensor to always be open and not pushed it etc. Look underneath by the pedals and you will see. Simple fix by getting a new piece from the dealership or a bolt and nut etc.
