need help- tach signal/afc neo
labelskater4
Car: 240sx
info:sr20det blacktop,stock ecu,s13 chassis
i had vivid racing try to install a safc neo in my car but the throttle and tach signal did not work on the neo-i fixed the throttle problem and now im trying to fix the tach signal-from what ive read on my searches apexi messed up on the instructions and people have had thier tach signal not work correctly on the neo's display screen-i know which wire is the tach signal on my ecu but i need to know which wire to hook it up to on the neo-any help would be appreciated (i looked at apexi's wiring diagram but couldnt tell which wire to use)
Blown240sx
Car: 1996 240sx
OOps lol sorry read the question wrong.
Modified by Blown240sx at 6:09 AM 12/4/2006
inertiadrft
Car: Do NOT be fool'ed by the low post count, The wise choose silence over Bla Bla Bla...
green on the neo, yellow/red stripe on the ecu...
afracer
Car: 92 240sx convertible, 72 Datsun, 69 Buick
Did you ever fix your problem??? Mine's doing the same thing.
KATwo40
Car: 1993 240sx KA-T
It's not a problem with the NEO harness wire, it's the wrong wiring pinout for the ECU.
Use diagram N3-b (NEO instructions say to use N3-a).
I just went through this.
EDIT*****
Blah...I just realized he's running an S14 engine/ecu. I found my above information to be true on the S13 (redtop) application. Sorry.
