need help
pturner12
Car: Nissan versa 2007 s
I have a 2007 nissan versa s the trunk button is not working from the outside but I am able to open it manually from inside by removing the cover an pulling the switchover which is now becomong incovienent an embarassing to my choldren how do I fix this without spending to much money helllllppppppp
float_6969
Do you have more than one keyfob you can test? (ie, is it just the button on the remote not working?) If it does this with more than one remote, chances are that the actuator inside the trunk latch has failed.
pturner12
I have two key fobs and both don't work I've also checked both fuse boxed and can't digure it out
float_6969
if that's the only issue ( I assume the doors unlocked with the fob), then it's either a bad ground (unlikely in such a new car) or the actuator for the trunk latch is bad (probably the issue ).
