Need Help!!
All things Altima Coupe.
Coupes08
Car: 2008 white nissan altima coupe 2.5
I have an 08 altima coupe, have d2 coils on and i cant go any lower because of my sway bar in the front. was wondering what kind should i get to go lower
MaximA32
Car: '98 Maxima (RIP)
'04 Maxima - Traded
'06 Mazda 6S- Traded
'15 Altima
I wouldn't recommend going lower than that since if you do, you're going to change the suspension geometry so much that you will burn through tires like there's no tomorrow since you won't be able to get the car properly aligned.
Coupes08
MaximA32 wrote:I wouldn't recommend going lower than that since if you do, you're going to change the suspension geometry so much that you will burn through tires like there's no tomorrow since you won't be able to get the car properly aligned.
My car isn't that low as of now I still have a tiny wheel gap in the front my sway bar is just way to long
