need help!!!
fullrunsilvia
Car: cars, girls, skateboarding
just tried to start my car tonite and it almost turned over but just not all the way, what are the most common troubleshootings? also, there are a couple plugs right by the firewall entrance that doesnt go anywhere, and what is #114 on the ecu, i got a black wire comming from that and dont know where it goes. hope you guys can help me, cause i wanna get my car started, thanks
SpeedRacer1
Car: 1990 240SX, G35
I doubt the 114 is whats actually going off. Thats the Automatic Transmission 2nd signal. There are usually a lot of plugs that are left unplugged so you will have to be specific. If its black, then 99% its a ground wire, so try grounding it. Timing is one of the most common issues if you touched the CAS at all. But so are ground wires and incorrect wiring.
fullrunsilvia
i need to know what #114 comming out of the ECU, not the fault code. i also have a coulple connectors that arent connected, one is a 6 pin connector near the brown power plug and its collors are blue w/ red stripe, blue w/ yellow stripe, and a ground (black). the next one is a 2 prong grey head and the colors ar oragne w/ blue stipe and a brown wire, and the last one is a 2prong black head and the colors are orange w/ black and a brown one. PLEASE HELP!!!! any ideas of trouble shooting, seems like im getting fuel and spark, tried ideas but if you guys could throw some more at me that would be great. thanks
loudbay
Car: duh
timing is probably your problem..... and your wire questions are hilarious =D... but seriously the motor will start with almost everything unplugged as long as the wiring is done correctly in the battery tray area and the dash area....
SpeedRacer1
The 6 prong connector may be important, but you only gave 3 wire colors, what about the others?
The Orange/blue and brown I havent looked checked my car, but it doesnt sound important. The orange/black and brown isnt important, mine isnt connected, its either EGR or boost sensor solenoid.
Pin 114 on the ECU has no wire, even on the auto ECU. So look again. http://sr20det.nismo.org/srtech.htm
gtune4
Car: toonah
http://www.nissaninfiniticlub....light
hope you can find something here
