GerryO »
https://forums.nicoclub.com/gerryo-u56567.html
Tue Apr 12, 2011 8:29 pm
So much fun. Pulled my plenum a couple of years ago at 170K miles to replace all six injectors, spark plugs, PCVs, EGR valve, etc. Also did the throttle body heating delete, and thoroughly cleaned the EGR tubes and MAF. Put things back together with my son's help; he had the passenger side of the plenum. Connected one O2 sensor to the KS and vice versa, and it took me a while to figure out that my son didn't connect the EGR lines.
Several codes, and a lot of thinking, inspecting and adjusting (CPS and TPS) later, all was fine and is still good. On one wet, damp morning the car started and ran very rough, but things quickly smoothed out and it's never happened again. Suspect it was wet, damp injector or coil pack connections, even though most connections got dielectric grease.
Not too longer after an O2 sensor started acting up so I replaced them both, improving fuel mileage. Still haven't replaced the length of metal tubing that heats the Air Regulator to pull the idle down while driving after cold starts.
Previous to all this the car sat a quite a while, waiting for water pump, timing belt, etc replacement. Have always tried to avoid jump-starting, preferring to simply charge batteries over night and if they don't hold a charge, they're bad. Weak batteries can cause strange behaviors.
Given the whole individual coil pack on spark plug and CPS distributor-free design of these engines, they should and can reliably purr at the lowest idle speeds. Best of luck.
