need help!!!!!!!!!!!!
mendez61414
Car: 240sx ka-t
ok i have a setup up with a t3/t4 turbo runnin 10lb of boost. my car when i drive it it like ride to rough. when u try to keep it steady speed it like jumps.. speeds up and it goes down.. help
wrightme43
Car: 1991 240SX SE, 5sp, Super Black
You will need to provide more information. Like what you have checked, what the results were, when it does it.
Based on the information you have provided so far my advice is to take it to a professional mechanic and allow them to repair your car.
If you can go into alot more detail you will most likely be able to understand what the cause and proper repair is.
not knocking you man, just trying to save you a bunch of time and heartache.
mendez61414
Car: 240sx ka-t
well ppl tell me its my tps sensor thats make it run like s***.. cuz it drives rough. i wanna make sure its my tps.. cuz i check codes and got knock sensor,maf, coolant,. so idk..
