NEED HELP!
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
samsss
Car: Nissan Bluebird 1993 Fwd sr20det
ive just fineshed putting my sr20det from a 4wd into my fwd u13 bluebird.its running fine apart from after driving it when its warm, once you turn it off it wont start again untill hours later after its cooled down.
any ideas????
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Did you change out the jdm temp sensor for your usdm sensor? What ecu are you using?
samsss
i used the same det loom and computer. as far as i know the plugs are where they shuld be...
samsss
how do i check if the sensors have been swaped?
RED_DET
Vendor
2011 Infiniti G37x
Does it start instantly after it is cooled down or does it struggle?
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
