NEED HELP
SRrunner
Car: SR20det s13 Fastback
I just rewired my new alternator in my SR (the Nissan quest alternator) and just redid my sound system (The only s*** i did) and i drove my 240 to my friends house and when i went to leave the car started sputtering and when ever i went over 7% throttle the engine would cut out plus i could only go to about 3000 RPMs if anyone has any ideas that would be awsome, im guessing a something regarding fuel but idk so if anyone know answer back ASAP its parked on the side of the road...
Hijacker
Car: '92 240sx Convertible
'94 F-150
Sounds like your MAF to me. Make sure the plug is secure. After that, if you have any kind of aftermarket piggy back system, be sure the MAF settings are still correctly set
SRrunner
i was thinking either that or the fuel pump.... should i be able to hear my fuel pump turn on cause i cant
Bongpain
Car: 92 240sx
well i can hear my pump all the time. so make sure you have correct fuel pressure. if not test the pump and wires to it + and - to pump. GL.
