tollboothwilley »
https://forums.nicoclub.com/tollboothwilley-u74535.html
Sun Oct 26, 2008 9:57 am
the exact opposite way you put it in...
make sure you loosen the nut that holds the tensioner pulley on.
that bolt that adjust the tension just moves the pulley up and down but the pulley won't move if you haven't loosened up that nut. You will likely just bend the bolt or break something if that nut is tight.
